Date/Time: Fri, 03 May 2024 04:32:32 +0000
Sierra Chart Globe
View Count: 813
[2014-11-27 18:46:22] |
User32803 - Posts: 18 |
For software version 1214. Is there a way to remove or change the colored world globe in the upper left hand corner of each chart and make it like previous versions of Sierra Chart? I find the colored globes quite distracting when viewing multiple charts within a chartbook.
[2014-11-27 21:13:02] |
That icon was not supposed to display on charts which are part of the main window. We will fix this.
