Date/Time: Mon, 29 Apr 2024 10:46:14 +0000
Maximum depth level in market depht window
View Count: 1872
[2014-11-27 10:29:19] |
nicktrader - Posts: 665 |
In the Chart DOM Settings I have a Maximum Depth Level displayed of 10 (standard for F.US.DD = 20) The Market Depth Window show me a level of 20. Is it possible to change the level in 10? |
[2014-12-03 05:24:48] |
I'd like to ask again. Is it possible to change the amount of line in the Depth Market Window? |
[2015-11-29 15:11:06] |
User931283 - Posts: 55 |
Did you try using Max Depth Displayed = 5 ? The setting may mean each side, bid or ask. I was just going to adjust mine, also, similarly. Until live FIX feed, I can not see the result. If you try 5 and get total of 10 levels, let us know. |
[2015-11-29 18:52:40] |
The answer is no and there are definitely no plans for this: Is it possible to change the amount of line in the Depth Market Window? Please do not request this feature because it will never be added. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-30 02:10:30] |
We will see about adding this capability but not for some time. The reason we do not want to add this is because inevitably the number of levels will get changed by someone and they wonder why they do not see all of the levels. The Market Depth window is designed to provide a complete and reliable view of all of the market depth levels. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-30 02:11:00
[2015-11-30 12:22:53] |
The big advantage of the Market Depth window are the sum rows because they are fix. It would be very helpful if there were the option - as for the DOM - to display the Depth market levels
DOM + MarketDepth.png / V - Attached On 2015-11-30 12:21:11 UTC - Size: 49.64 KB - 420 views |
