Date/Time: Wed, 08 May 2024 00:04:50 +0000
Ask vs Bid Vol
View Count: 1371
[2014-11-26 22:37:54] |
User121729 - Posts: 37 |
I love SC.. but need accurate data on bid vol vs ask vol.. I currently use TTNet through Amp but some of the data does not make sense to me at times.. I have no way to compare it, but is TTNET accurate in terms of bid vol vs ask vol? I know SC has an accurate data feed.. but how about CQG data thru AMP or even TOS data ? I have used Rithmic through Optimus Futures and it seemed accurate, but I understand the Rithmic feed thru AMP does not provide bid vol vs ask vol.. Is that correct? Thanks |
[2014-11-27 03:27:20] |
TTNET does not provide accurate bid trade volume or ask trade volume. The easiest solution would be to ask AMP to switch you over to CQG. Sierra Chart does now support historical ask/bid volume with Rithmic but there is a limitation where the most recent 10 minutes of historical data will not have that data upon connection. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-27 19:50:41
[2014-11-27 12:08:01] |
Does Rithmic through Optimus have this same limitation?
[2014-11-27 19:51:09] |
Rithmic through Optimus does not have this limitation with the most recent 10 minutes of historical Intraday data.
