Date/Time: Wed, 01 May 2024 22:17:21 +0000
Tim
View Count: 939
[2014-11-26 20:22:41] |
User537081 - Posts: 7 |
Downloaded and using sierra chart latest version today 26/11/2014. This version has not got "numbers bars - old" which I like to use as it has more customisation flexibility than "Number Bars". Tried to install previous versions within the same folder to replace the most recent version. Every time I try to install a previous set up version from the list I get an error message - Error opening file for writing" to my folder path and am asked to click "abort." What I am aiming for is to use your new feature, "volume at price threshold alert" with "numbers bars-old" Any help gratefully received. Thanks Tim. |
[2014-11-26 20:29:08] |
The new Numbers Bars study definitely has more customization capability, then the old version of that study. What is one of the items that you want to do that seems like you cannot with the new Numbers Bars study? When you are installing an older version make sure the existing copy of Sierra Chart is not running. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-11-26 20:56:09] |
Looking just at Bid Vol x Ask Vol i want to colour the text on the dominant side red, or green with the opposing side ( the less dominant side) white ( I use a black background). i have nothing available in the subgraphs tab.
[2014-11-27 12:20:00] |
OK I have sorted out my problem now. I just needed to adjust the "compare thresholds"
[2014-12-01 08:45:27] |
For reference, here is the relevant documentation: http://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php#DominantSideColoring Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
