Date/Time: Mon, 06 May 2024 14:20:15 +0000
Vertical Line via Spreadsheets
View Count: 930
[2014-11-26 17:14:51] |
infpz - Posts: 826 |
Is there a way to draw a vertical line when a condition is met? The only dynamic drawings ability I could find is a horizontal line.
[2014-11-26 18:42:01] |
The easiest way to do this is to use the Background Draw Style for one of the Spreadsheet Study Subgraphs and return a nonzero value in the corresponding Sheet column. Or you could use Bar Top and Bar Bottom Draw Style pairs and use 2 Sheet columns and return values of 2 and 1 respectively. You will need to use an Independent scale in this case. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
