Date/Time: Mon, 20 May 2024 01:27:18 +0000
Hedging functionality
View Count: 1142
[2014-11-26 04:43:05] |
User79541 - Posts: 9 |
Is there any possible way for enabling edging functionality on autotrad?
[2014-11-26 08:33:38] |
Yes and we are working on documentation for this.
[2014-11-26 12:18:16] |
how long before I can use it?
[2014-11-27 04:03:21] |
Here is the documentation we said we would prepare for this: FXCM Trading Service: Trading Multiple Accounts/Hedging Make sure you are running Sierra Chart version 1214 which we are releasing now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
