Date/Time: Mon, 06 May 2024 02:41:30 +0000
Sierra Charts not activating
View Count: 834
[2014-11-25 17:17:49] |
Roy Pontier - Posts: 6 |
system not booting get some error messages (which I always get) but system hangs cannot change anything. Help !!! Tried loading latest version but no change. Message Log does not go to completion took snapshot and attached file
Private File |
[2014-11-25 17:44:43] |
Exit from Sierra Chart and go to the the Sierra Chart Data Files Folder. This usually is C:\SierraChart\data Delete the following files: AB`Z4.scid NQ`Z.scid There are data errors which apparently are causing a problem. You may also want to be aware of the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-11-25 17:46:37] |
Problem solved Msg board minimized saw a problem --- bad data reloaded data from provider (Mytrack) and now up and running no need to reply
