Date/Time: Sun, 05 May 2024 02:49:10 +0000
confirmations
View Count: 851
[2014-11-25 09:56:36] |
navigator - Posts: 25 |
When trading from the chart, when I adjust an order I am getting an order modification request. From the DOM menu and confirmations I have none of the confirmations ticked or enabled. How do I disable the order modification requests? Thanks
[2014-11-25 17:42:35] |
You need to disable the confirmations on the Trade Window for the specific chart or Trade DOM itself. Each one has its own Trade Window and settings. Refer to the documentation for this here: https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#OrderConfirmations Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
