Date/Time: Sun, 28 Apr 2024 21:34:47 +0000
ES historical data has sequence number instead of fractions of seconds
View Count: 835
[2014-11-24 13:20:08] |
Corben - Posts: 4 |
I got my trial SC. I loaded ES historical intraday data. When I replay a ESZ14 chart after ES cash session opening (which supposed to be very active) I only see timestamps with numbers which look like a sequential number rather (and they start from 0 when your T&S restarted). Is there a document which describes this? does that mean that SC doesnt support millisecond stamps? |
[2014-11-24 22:50:00] |
Refer to the Time field here for an explanation of this: https://www.sierrachart.com/index.php?page=doc/doc_TimeandSalesWindow.html#ColumnDescriptions Sierra Chart does not support the true millisecond timestamps . Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
