Date/Time: Sat, 15 Nov 2025 14:33:53 +0000
T&S for TICK doesnt show fractions of seconds
View Count: 1001
| [2014-11-24 13:12:58] |
| Corben - Posts: 4 |
If you replay a TICK chart with T&S open then there are only whole seconds in the timestamp. However there are 3 records per 1 sec step (in chart replay). So I assume the 3 records must have different timestamp but they have the same always.
| [2014-11-24 22:47:53] |
Refer to the description for the Time field for an explanation of this: Time and Sales Window: Column Descriptions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
