Date/Time: Fri, 30 Oct 2026 15:10:45 +0000
CQG "can not submit order during initial order snapshot"
View Count: 2616
[2014-12-02 00:10:41]
We just ran a test now wwith the CQG Web API Service and looked at all of the order fields and they all are present and correct:
Entry Time  Last Activity Time  Symbol  Parent Internal Order ID  Status  Internal Order ID  Service Order ID  Client Order ID  Order Type  Buy/Sell  Open/Close  Order Quantity  Price  Price 2  Filled Quantity  Average Fill Price  Time in Force  Good Till DateTime  Trade Account  Link ID  OCO ID  LastOrderActionSource
2014-12-01 19:07:58  2014-12-01 19:09:12  F.US.ENQZ14  0  Open  5447  413208538  5447.1  Limit  Sell  Open  1  4289.00  0.00  0  0.00  Day    SIMSierraChart  0  0  CQG order update (Ack Place)
2014-12-01 19:07:56  2014-12-01 19:09:12  F.US.ENQZ14  0  Filled  5446  413189269  5446.1  Limit  Sell  Open  1  4288.50  0.00  3  4288.50  Day    SIMSierraChart  0  0  CQG order update (Fill)
2014-12-01 19:07:54  2014-12-01 19:09:12  F.US.ENQZ14  0  Open  5445  413208537  5445.1  Limit  Buy  Open  1  4285.50  0.00  0  0.00  Day    SIMSierraChart  0  0  CQG order update (Ack Place)
2014-12-01 19:07:52  2014-12-01 19:09:12  F.US.ENQZ14  0  Open  5444  413199042  5444.1  Limit  Buy  Open  1  4285.75  0.00  0  0.00  Day    SIMSierraChart  0  0  CQG order update (Ack Place)
Including after a fill. One of these orders filled above.
We recommend changing the Service in Sierra Chart to CQG FIX Trading. That should be more reliable.
We are certain these issues are on the CQG side.
Date Time Of Last Edit: 2014-12-02 00:12:00
[2014-12-02 00:14:58]
We do see a problem with the "Filled Quantity" field and we are fixing that, but that is not anything which would cause a problem.
[2014-12-02 13:59:34]
cmb999 - Posts: 211
thank you for the CQG Fix option. I don't remember changing to WebAPI, but i will go with tried -and-true, and so far, it is working great . .
[2014-12-02 17:51:00]
Yes. FIX is the best.
The reason we added support for the web API is because CQG charges another $10 for the FIX connection and they will not remove this additional charge. But this CQG web API has problems.
[2014-12-02 20:26:33]
opmetal - Posts: 74
So is there any reason for us end users to bother with the CQG WebAPI connection? It seems far too buggy for trading applications.
[2014-12-02 20:51:00]
If you are fine paying the extra $10 a month, then do not bother with CQG Web API. We wish we never got involved with it. And we have communicated our views to CQG about this.
Date Time Of Last Edit: 2014-12-02 20:51:18
[2014-12-02 21:00:57]
opmetal - Posts: 74
Where is this $10 price difference noted on your site?
[2014-12-02 21:11:04]
This pricing is not from Sierra Chart, it is from CQG which is billed to the FCM. So this would not be stated on the Sierra Chart website because we have no definite knowledge about this or how the FCM handles it.
