Date/Time: Sun, 19 May 2024 21:54:14 +0000
[User Discussion] - Zig Zag Alert - Higher Low on Higher Voume or Lower High on Higher Volume
View Count: 1470
[2014-11-23 07:16:05] |
Halco - Posts: 92 |
Is such an alert possible? Thanks!
[2014-11-23 12:34:12] |
Halco - Posts: 92 |
Lemme rephrase that: Is it possible to create such an alert with just a formula or would this require a spreadsheet study? I ask because if it's a formula maybe I can figure it out, but if it requires a spreadsheet study that's beyond my capabilities and I won't waste my time. Thanks much.
[2014-11-23 15:06:04] |
Sawtooth - Posts: 4001 |
It's possible but it would require a spreadsheet study.
[2014-11-23 16:10:51] |
Halco - Posts: 92 |
Argh! Ok, thanks Tom.
[2014-11-24 22:19:57] |
lotus123 - Posts: 23 |
if i understand you correctly, Halco, you can do this. use the indicator "color bar based on alert condition". in the alert tab you can put this formula - "=and( L>L[-1] , V>V[-1])" ,don't type quotes. which means color the bar when BOTH the low is greater than the previous low, AND the volume is greater than the previous volume. i don't know what you would do with the zigzag part. |
