Date/Time: Tue, 07 May 2024 18:12:27 +0000
FXCM limit entry order and OCO stop/target
View Count: 1360
[2014-11-21 19:34:53] |
N!co - Posts: 140 |
Hi, Is it supported that the OCO stop/tagets are submitted at the same time a limit order is entered ?? Right now, the stop/targets are submitted as soon as the limit order is filled but this leaves a risk if is connection is lost the pending limit order rests without the stop/taget orders thx |
[2014-11-21 21:44:25] |
Only after the parent order fills.
[2014-11-23 23:37:44] |
N!co - Posts: 140 |
Is it possible to submit the stop/limit orders at the same time as the parent order is submitted ? just as it is possible directly from the fxcm trade station and so there is no risk of leaving an order resting without a stop/limit thx |
[2014-11-24 00:12:12] |
Either it is not possible with the FIX protocol, or the FXCM FIX implementation is incompatible with what Sierra Chart requires.
