Date/Time: Sat, 04 May 2024 02:05:55 +0000
Numbers Bar Cumualtive Volume -Day vs. Transact DOM volume
View Count: 920
[2014-11-21 16:05:58] |
Handle - Posts: 36 |
Reference contract TFZ4 . What would be the explanation for the Transact DOM reporting substantially less volume then the the Number Bar Calculated Values for Cum Volume? For today for example at the moment the Transact DOM shows 53,690 vs 83,690 contracts on the Number Bar calc value. Also, I timed a 2 minute period and the Transact Dom reported 338 contracts less then the Calc value.
[2014-11-21 17:45:10] |
Refer to help topic 43: Http://www.sierrachart.com/index.php?page=doc/helpdetails43.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
