Date/Time: Mon, 29 Apr 2024 01:01:16 +0000
Export Intra Day data to text file
View Count: 896
[2014-11-20 20:52:07] |
ertrader - Posts: 645 |
Hi Support, When exporting intra-day data to text file, how can I export the entire data set in one file that uses the displayed data as: "Use number of days to load"? I do see all the data in the SC chart but the EXPORTED text file only contains data from: "Date Range In file" I must be doing something simple incorrectly because I just want the entire exported date range "Use number of days to load" in one file. Thank you Date Time Of Last Edit: 2014-11-20 20:52:52
SCExportt.JPG / V - Attached On 2014-11-20 20:51:42 UTC - Size: 95.92 KB - 290 views |
[2014-11-20 21:21:56] |
We understand. Since this is a Continuous Futures Contract chart, there are multiple data files loaded into the chart. To accomplish what you want, use this study: Http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s182 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-20 21:22:17
