Date/Time: Tue, 07 May 2024 11:05:01 +0000
Volume value text moved
View Count: 875
[2014-11-20 20:01:03] |
User15302 - Posts: 5 |
Hi guys, is there a way to have the value text moved to the right hand side from the left side? Please see attached picture which shows what I mean. Thanks |
Untitled.png / V - Attached On 2014-11-20 20:00:38 UTC - Size: 8.24 KB - 328 views Attachment Deleted. |
[2014-11-21 18:33:57] |
What you can do is enable the Name and Value labels for study Subgraphs. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#NameValueLabels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
