Date/Time: Tue, 07 May 2024 11:54:35 +0000
Chart and orders questions
View Count: 1100
[2014-11-20 11:56:20] |
User46930 - Posts: 28 |
I have few questions, 1. cannot see yesterday and before live account fills shown on the chart even with Show Fills enabled 2. Horizontal grid lines are shown only on detached charts. Attached 6 range chart won't show it 3. If I understand the changes made with AMP CQG regarding OCO well then if I have a open position and profit-target + stop-loss are sent as limit and stop orders (open state) there is still a server-side OCO relation between them. Can I shut PC down then when I am in a position? See the screen here http://tomas262.savana-hosting.cz/2014-11-20_12-44-40.png |
[2014-11-20 18:57:45] |
1. Uncheck Chart >> Chart Settings >> Advanced Settings >> Load Order Fills for Current Day Only. 2. Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_ChartMenu.html#grid Might be something with the color setting of the Grid Lines. It could be the same as the background color. Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html Charts can have their own independent color setting from the global color settings. Also make sure that you have enabled the Horizontal Grid for Chart Region 1 or all regions. 3. In the newer versions of Sierra Chart, there is no longer any server-side OCO with CQG because CQG does not support it with their web API. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-20 18:58:18
