Date/Time: Mon, 29 Apr 2024 10:29:48 +0000
Error: 'class s_UseTool' has no member named 'UseRelativeValue'
View Count: 1031
[2014-11-20 09:47:36] |
User33803 - Posts: 40 |
In Release 1213 I cannot compile my ACSIL function due to "error: 'class s_UseTool' has no member named 'UseRelativeValue'". Everytime I have a tool where I try to set the UseRelativeValue I've got the same problem. I come from Release 1205 and I never had that problem for that Release nor the previous ones. I have tried to install R1213 from scratch (just in case some file is missing) and it does not work either. When I return to R1205 the file compiles again. Date Time Of Last Edit: 2014-11-20 09:48:58
[2014-11-20 10:14:22] |
This has been renamed to UseRelativeVerticalValues. This change is documented on the What is New page. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
