Date/Time: Mon, 02 Nov 2026 14:18:13 +0000
Sierra freezed doesn't connect
View Count: 1304
[2014-11-19 16:33:03]
User95457 - Posts: 19
Software version: 1202 | 2014-11-19 10:22:07
Usage end date: 2014-11-27 | 2014-11-19 10:22:07
Enabled for: Advanced Features. | 2014-11-19 10:22:07
Enabled for: Sierra Chart Historical Data Service. | 2014-11-19 10:22:07
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-11-19 10:22:07
Active service: Rithmic Trading | 2014-11-19 10:22:07
Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-11-19 10:22:07
2014-11-19 17:22:07 Local computer clock time | 2014-11-19 10:22:07
2014-11-19 16:22:07 GMT time | 2014-11-19 10:22:07
2014-11-19 10:22:07 Time zone adjusted time | 2014-11-19 10:22:07
Time difference to server time: 1 seconds. | 2014-11-19 10:22:07
Program path: C:\SierraChart\ | 2014-11-19 10:22:07
Data Files path: C:\SierraChart\Data\ | 2014-11-19 10:22:07
OS Version Number: 6.1 | 2014-11-19 10:22:07
Locale Information: English_United States.1252 | 2014-11-19 10:22:07
Checking for new symbol settings for rim | 2014-11-19 10:22:07
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 88.198.13.175 | 2014-11-19 10:22:07
HTTP connection to www.sierrachart.com:80 (920) | Connected. | 2014-11-19 10:22:07
Symbol settings are up-to-date for rim | 2014-11-19 10:22:08
Rithmic Trading | Port for executable: 50890 | 2014-11-19 10:22:12
Listening socket (1444), port 50890 | Closed. | 2014-11-19 10:22:12
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-11-19 10:22:12
HTTP connection to www.sierrachart.com:80 (920) | Closed. No error. | 2014-11-19 10:22:13
HTTP connection to www.sierrachart.com:80 (920) | Shutdown and closed. | 2014-11-19 10:22:13
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50890 | 2014-11-19 10:22:14
Socket (924) | Connected. | 2014-11-19 10:22:14
Rithmic Trading | Connected to server. | 2014-11-19 10:22:14
Rithmic Trading | Sending logon request message. | 2014-11-19 10:22:14
Rithmic Trading | Starting the connection process to data and trading service. | 2014-11-19 10:22:14
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-11-19 10:22:14
Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2014-11-19 10:22:14
Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-11-19 10:22:17
Rithmic Trading | Server Alert: Trading System Connection Opened | 2014-11-19 10:22:19
Rithmic Trading | Server Alert: PnL Connection Opened | 2014-11-19 10:22:20
Rithmic Trading | Server Alert: Intraday History Connection Opened | 2014-11-19 10:22:21
Connection timed out. Will disconnect and retry. | 2014-11-19 10:24:12 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-19 10:24:12
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-19 10:24:12
Socket (924) | Shutdown and closed. | 2014-11-19 10:24:12
Rithmic Trading | Disconnected from the server. | 2014-11-19 10:24:12
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-19 10:24:12
Rithmic Trading | Port for executable: 51026 | 2014-11-19 10:24:14
Listening socket (1448), port 51026 | Closed. | 2014-11-19 10:24:14
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-11-19 10:24:14
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51026 | 2014-11-19 10:24:16
Socket (1448) | Connected. | 2014-11-19 10:24:16
Rithmic Trading | Connected to server. | 2014-11-19 10:24:16
Rithmic Trading | Sending logon request message. | 2014-11-19 10:24:16
Rithmic Trading | Starting the connection process to data and trading service. | 2014-11-19 10:24:16
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-11-19 10:24:16
Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2014-11-19 10:24:16
Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-11-19 10:24:19
Rithmic Trading | Server Alert: Trading System Connection Opened | 2014-11-19 10:24:21
Rithmic Trading | Server Alert: PnL Connection Opened | 2014-11-19 10:24:22
Rithmic Trading | Server Alert: Intraday History Connection Opened | 2014-11-19 10:24:23
Connection timed out. Will disconnect and retry. | 2014-11-19 10:26:14 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-19 10:26:14
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-19 10:26:14
Socket (1448) | Shutdown and closed. | 2014-11-19 10:26:14
Rithmic Trading | Disconnected from the server. | 2014-11-19 10:26:14
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-19 10:26:14
Rithmic Trading | Port for executable: 51056 | 2014-11-19 10:26:16
Listening socket (920), port 51056 | Closed. | 2014-11-19 10:26:16
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-11-19 10:26:16
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51056 | 2014-11-19 10:26:18
Socket (920) | Connected. | 2014-11-19 10:26:18
Rithmic Trading | Connected to server. | 2014-11-19 10:26:18
Rithmic Trading | Sending logon request message. | 2014-11-19 10:26:18
Rithmic Trading | Starting the connection process to data and trading service. | 2014-11-19 10:26:19
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-11-19 10:26:19
Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2014-11-19 10:26:19
Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-11-19 10:26:21
Rithmic Trading | Server Alert: Trading System Connection Opened | 2014-11-19 10:26:23
Rithmic Trading | Server Alert: PnL Connection Opened | 2014-11-19 10:26:24
Rithmic Trading | Server Alert: Intraday History Connection Opened | 2014-11-19 10:26:25
Rithmic Trading | Server Alert: Intraday History Connection Login Failed. Result text: "permission denied" | 2014-11-19 10:27:13
Rithmic Trading | Server Info - Server Name: DTC Bridge. | 2014-11-19 10:27:13
Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-11-19 10:27:13
Rithmic Trading | Logon error from server | 2014-11-19 10:27:13
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-19 10:27:14
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-19 10:27:14
Rithmic Trading | Deleting API object. | 2014-11-19 10:27:14
Rithmic Trading | Server Alert: Intraday History Connection Closed | 2014-11-19 10:27:14
Rithmic Trading | Server Alert: PnL Connection Closed | 2014-11-19 10:27:14
Rithmic Trading | Server Alert: Trading System Connection Closed | 2014-11-19 10:27:14
Rithmic Trading | Server Alert: Market Data Connection Closed | 2014-11-19 10:27:14
Socket (920) | Shutdown and closed. | 2014-11-19 10:27:14
Rithmic Trading | Disconnected from the server. | 2014-11-19 10:27:14
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-19 10:27:14
Rithmic Trading | Port for executable: 51079 | 2014-11-19 10:27:16
Listening socket (1552), port 51079 | Closed. | 2014-11-19 10:27:16
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-11-19 10:27:16
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51079 | 2014-11-19 10:27:18
Socket (1552) | Connected. | 2014-11-19 10:27:18
Rithmic Trading | Connected to server. | 2014-11-19 10:27:18
Rithmic Trading | Sending logon request message. | 2014-11-19 10:27:18
Rithmic Trading | Starting the connection process to data and trading service. | 2014-11-19 10:27:18
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-11-19 10:27:18
Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2014-11-19 10:27:18
Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-11-19 10:27:20
Rithmic Trading | Server Alert: Trading System Connection Opened | 2014-11-19 10:27:22
Rithmic Trading | Server Alert: PnL Connection Opened | 2014-11-19 10:27:23
Rithmic Trading | Server Alert: Intraday History Connection Opened | 2014-11-19 10:27:25
Rithmic Trading | Server Alert: Intraday History Connection Login Failed. Result text: "permission denied" | 2014-11-19 10:29:13
Rithmic Trading | Server Alert: Intraday History Connection Closed | 2014-11-19 10:29:13
Rithmic Trading | Server Info - Server Name: DTC Bridge. | 2014-11-19 10:29:13
Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-11-19 10:29:13
Rithmic Trading | Logon error from server | 2014-11-19 10:29:13
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-19 10:29:13
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-19 10:29:13
Rithmic Trading | Deleting API object. | 2014-11-19 10:29:14
Rithmic Trading | Server Alert: PnL Connection Closed | 2014-11-19 10:29:14
Rithmic Trading | Server Alert: Trading System Connection Closed | 2014-11-19 10:29:14
Rithmic Trading | Server Alert: Market Data Connection Closed | 2014-11-19 10:29:14
Socket (1552) | Shutdown and closed. | 2014-11-19 10:29:14
Rithmic Trading | Disconnected from the server. | 2014-11-19 10:29:14
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-19 10:29:14
Rithmic Trading | Port for executable: 51415 | 2014-11-19 10:29:16
Listening socket (2088), port 51415 | Closed. | 2014-11-19 10:29:16
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-11-19 10:29:16
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51415 | 2014-11-19 10:29:18
Socket (2396) | Connected. | 2014-11-19 10:29:18
Rithmic Trading | Connected to server. | 2014-11-19 10:29:18
Rithmic Trading | Sending logon request message. | 2014-11-19 10:29:18
Rithmic Trading | Starting the connection process to data and trading service. | 2014-11-19 10:29:18
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-11-19 10:29:18
Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2014-11-19 10:29:18
Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-11-19 10:29:20
Rithmic Trading | Server Alert: Trading System Connection Opened | 2014-11-19 10:29:22
Rithmic Trading | Server Alert: PnL Connection Opened | 2014-11-19 10:29:23
Rithmic Trading | Server Alert: Intraday History Connection Opened | 2014-11-19 10:29:24
Connection timed out. Will disconnect and retry. | 2014-11-19 10:31:16 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-19 10:31:16
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-19 10:31:16
Socket (2396) | Shutdown and closed. | 2014-11-19 10:31:16
Rithmic Trading | Disconnected from the server. | 2014-11-19 10:31:16
Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-19 10:31:16
Rithmic Trading | Port for executable: 51457 | 2014-11-19 10:31:18
Listening socket (2004), port 51457 | Closed. | 2014-11-19 10:31:18
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-11-19 10:31:18
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51457 | 2014-11-19 10:31:20
Socket (2004) | Connected. | 2014-11-19 10:31:20
Rithmic Trading | Connected to server. | 2014-11-19 10:31:20
Rithmic Trading | Sending logon request message. | 2014-11-19 10:31:20
Rithmic Trading | Starting the connection process to data and trading service. | 2014-11-19 10:31:20
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-11-19 10:31:20
Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2014-11-19 10:31:20
Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-11-19 10:31:22
Rithmic Trading | Server Alert: Trading System Connection Opened | 2014-11-19 10:31:24
Rithmic Trading | Server Alert: PnL Connection Opened | 2014-11-19 10:31:25
Rithmic Trading | Server Alert: Intraday History Connection Opened | 2014-11-19 10:31:26
[2014-11-19 17:40:57]
We are aware that Rithmic had a problem earlier today. Maybe it is related to this. The problem is the Rithmic server is not responding properly during the connection and logon process:
Are you still having a problem connecting to Rithmic? Select File >> Connect to Data Feed to connect.
