Date/Time: Sun, 05 May 2024 12:07:05 +0000
User Email Question
View Count: 1682
[2013-05-16 17:09:14] |
Sierra Chart - Max - Posts: 5605 |
Could you explain me, whay is different Volume and Last (close) price in daily chart ( in Tool Values window) ? For example 2013-05-14 , TFM3 Last price in Daily chart - is 984.4 (we can see in Tool Values) but in 1 min. chart - we can see that last price is 983.2 (2013-05-14 23:40:00) also sum volume from 1 hour chart not the same like in daily chart from 1 hour chart volume is bigger. Could you explain me why there is always difference. I thing it can not be mistake in SireraChart. Sierra Chart Support |
[2013-05-16 17:11:41] |
Please refer to this section here: http://www.sierrachart.com/index.php?l=doc/helpdetails43.html#h43.6 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
