Date/Time: Fri, 03 May 2024 15:24:29 +0000
Times out of order on 5min, and 1min no data since 12:10
View Count: 984
[2014-11-17 19:36:08] |
tfh6252 - Posts: 20 |
Reloaded all charts, deleted all data and downloaded. the 1min is not updating, since 12:10, and the 5min has timestamp sequencing errors. The last log entry received as of now is listed below at 13:22. http://www.sierrachart.com/image.php?l=141625286199.png http://www.sierrachart.com/image.php?l=1416252913987.png ESZ4-CME [CB] 5 Min #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-17 13:10:00. Next Bar Date Time: 2014-11-17 10:45:00. Filename: C:\SierraChart\Data\ESZ4-CME.scid | 2014-11-17 13:18:38 ESZ4-CME [CB] 30 Min #4 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-17 13:00:00. Next Bar Date Time: 2014-11-17 10:30:00. Filename: C:\SierraChart\Data\ESZ4-CME.scid | 2014-11-17 13:18:42 Chart #4 has tagged chart #19 for full recalculation. Chartbook: RithmicES.cht | 2014-11-17 13:18:43 Chart #4 has tagged chart #9 for full recalculation. Chartbook: RithmicES.cht | 2014-11-17 13:18:43 Chart #15 has tagged chart #19 for full recalculation. Chartbook: RithmicES.cht | 2014-11-17 13:18:47 Chart #15 has tagged chart #9 for full recalculation. Chartbook: RithmicES.cht | 2014-11-17 13:18:47 ESZ4-CME [CB] 1 Min #9 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-17 13:13:00. Next Bar Date Time: 2014-11-17 10:48:00. Filename: C:\SierraChart\Data\ESZ4-CME.scid | 2014-11-17 13:18:50 Chart #9 is performing a full recalculation because it has been tagged. Chartbook: RithmicES.cht | 2014-11-17 13:18:52 ESZ4-CME [CB] 30 Min #18 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-17 13:00:00. Next Bar Date Time: 2014-11-17 10:30:00. Filename: C:\SierraChart\Data\ESZ4-CME.scid | 2014-11-17 13:18:56 Chart #19 is performing a full recalculation because it has been tagged. Chartbook: RithmicES.cht | 2014-11-17 13:19:01 Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2014-11-17 13:22:54 Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2014-11-17 13:22:54 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-17. | 2014-11-17 13:22:54 ESZ4-CME [CB] 1 Min #9 | Symbols used for continuous contract chart: | 2014-11-17 13:22:54 ESZ4-CME | 2014-11-17 13:22:54 ESZ4-CME [CB] 1 Min #9: Performing continuous futures contract back adjustment calculations. | 2014-11-17 13:22:54 |
[2014-11-18 07:53:12] |
Update Sierra Chart by selecting Help >> Download Current Version. We do not think the version has anything to do with it, but it is good idea to be on the current version. Re-download the data in the chart with this command and only this command and do not use any other command: Edit >> Delete All Data and Download Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
