Date/Time: Mon, 06 May 2024 22:34:18 +0000
4Hour chart has very limited data available
View Count: 894
[2014-11-15 19:00:42] |
User37537 - Posts: 78 |
Hello, I am still using my demo account with the default data feeds. On any currency pair when I switch to a 4h chart, I have very little data. There is not even enough to fill the screen and the scroll bar at the bottom is inactive, suggesting there is no data to scroll back to. All other time periods are fine. Is there a setting I have overlooked? http://www.sierrachart.com/image.php?l=1416078120913.png Date Time Of Last Edit: 2014-11-15 19:02:24
[2014-11-15 19:02:14] |
Refer to help topic 42.1: http://www.sierrachart.com/index.php?page=doc/helpdetails42.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
