Date/Time: Thu, 02 May 2024 12:49:06 +0000
200 ma doesnt show up in some timeframes and chart does not go to historical data years back
View Count: 849
[2014-11-15 17:01:30] |
User15903 - Posts: 3 |
Hi everyone! I need help regarding 200 ma. I have noticed that it does not show up in some timeframes especially the 240 minute timeframe. I am trading major pairs. Also, upon dragging the chart to see historical data years back, I am not able to do that. Any help for this one? I have purchased 2nd to the last package which is about 30 euros if im not mistaken. Thank you |
[2014-11-15 19:49:57] |
User37537 - Posts: 78 |
I just had a similar problem, this fixed it for me: Chart -> Chart Settings -> Use Number Of Days To Load Make sure this is a large number, and large enough for the 200MA to get the data it needs for its calculation. |
[2014-11-18 01:08:55] |
Refer to help topic 42.1 for help with this: http://www.sierrachart.com/index.php?page=doc/helpdetails42.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
