Date/Time: Thu, 14 May 2026 10:16:56 +0000
Problem downloading SPX and VIX intraday (and others)
View Count: 1302
| [2014-11-15 00:53:45] |
| rhovega - Posts: 279 |
I can't get SC to download/plot SPX or VIX intraday. The data source for these indexes is IB. SPX and VIX show fine on my IB platform. I can plot them intraday. The feed works. Using $SPX and $VIX symbols SC downloads the daily data but not the intraday data. Can you please help with this? Why does SC download the daily data and not the intraday data? The fact that the daily works indicates that the problem is not the data feed. I may be wrong. Thank you |
| [2014-11-15 04:43:51] |
These symbols are Sierra Chart index symbols and require that you activate the corresponding exchanges on the Sierra Chart Exchange Data feed in order to get Intraday data and real-time data for them. Otherwise, you need to use the equivalent IB symbols which you can find in File >> Find Symbol >> IB Indexes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-15 04:44:07
