Date/Time: Fri, 18 Jul 2025 23:01:16 +0000
[User Discussion] - Using extra array from another study
View Count: 1484
[2014-11-14 23:55:47] |
User43906 - Posts: 4 |
Hello, i need to call another study and extract an extra array (four position) The call is: sc.GetStudyExtraArrayFromChartUsingID(sc.Input[2].GetChartNumber(), sc.Input[0].GetInt(), 0, 4, StudyReference1);
In the other study I set muy values in ZigZagPeakValue arraySCFloatArrayRef ZigZagPeakType = ZigZagLine.Arrays[0]; // ZigZagPeakType : +1=high peak, -1=low peak, 0=not peak SCFloatArrayRef ZigZagPeakIndex = ZigZagLine.Arrays[1]; // ZigZagPeakIndex: index of current peak, -1=no peak yet SCFloatArrayRef ZigZagReset = ZigZagLine.Arrays[2]; // ZigZagReset: 0=no reset, 1=reset SCFloatArrayRef ZigZagTrend = ZigZagLine.Arrays[3]; // ZigZagTrend: 0=none, 1=confirmed up, -1=confirmed down SCFloatArrayRef ZigZagPeakValue = ZigZagLine.Arrays[4]; ZigZagPeakValue[ZigZagIndex] = 4; float ValorStudy1 = StudyReference1[sc.Index]; Thanks! Date Time Of Last Edit: 2014-11-14 23:59:07
[2014-11-18 01:40:39] |
The most likely reason for this is you are not finding the corresponding index in the Study Subgraph array the code is referencing from another chart, since it is from another chart and the array does not match with the destination chart. Refer to this page for more information: Referencing Other Time Frames and Symbols When Using the ACSIL Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-24 17:42:09
[2014-11-21 16:02:14] |
Ok thanks a lot! I think i'm not setting well the Study/Price Overlay, In the standard procedence which one i need to choose in the Based On option? Then, in Study Overlay option i choose of course the one i need to call and then in the call i set the Study Id of this (Study/Price Overly)? How does the parameter chart number work? Thanks for your help! |
[2014-11-24 17:44:23] |
Study/Place Overlay does not required to use the Based On setting. Then, in Study Overlay option i choose of course the one i need to call and then in the call i set the Study Id of this (Study/Price Overly)?
Yes, this is right. To reference the data from the Study/Price Overlay study, use sc.GetStudyArrayUsingID. Since the data is on the same chart.
