Date/Time: Fri, 03 May 2024 18:51:11 +0000
amp rithmic connection faillure
View Count: 926
[2014-11-14 16:58:25] |
User61950 - Posts: 3 |
hi i suscribe to amp for demo request with rithmic data feed i'm ok with my sierra chart account i restart my sc but it still impossible to connect can you help me AMP/TTNet | Connecting. | 2014-11-14 17:55:39 TT FIX Data | Connecting to 208.95.248.77. Port 10501 | 2014-11-14 17:55:39 TT FIX Data socket (1108) | Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-11-14 17:55:41 TT FIX Data socket (1108) | Shutdown and closed. | 2014-11-14 17:55:41 TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2014-11-14 17:55:41 Disconnected from TT FIX Price Feed session. | 2014-11-14 17:55:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-14 17:55:41 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-14 17:55:41 AMP/TTNet | Disconnected. | 2014-11-14 17:55:41 Will reconnect to the server in 5.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-14 17:55:41 AMP/TTNet | Connecting. | 2014-11-14 17:55:46 TT FIX Data | Connecting to 208.95.248.77. Port 10501 | 2014-11-14 17:55:46 TT FIX Data socket (1080) | Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-11-14 17:55:49 TT FIX Data socket (1080) | Shutdown and closed. | 2014-11-14 17:55:49 TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2014-11-14 17:55:49 Disconnected from TT FIX Price Feed session. | 2014-11-14 17:55:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-14 17:55:49 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-14 17:55:49 AMP/TTNet | Disconnected. | 2014-11-14 17:55:49 Will reconnect to the server in 5.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-14 17:55:49 AMP/TTNet | Connecting. | 2014-11-14 17:55:54 TT FIX Data | Connecting to 208.95.248.77. Port 10501 | 2014-11-14 17:55:54 File >> Disconnect selected. | 2014-11-14 17:55:56 TT FIX Data socket (1080) | Shutdown and closed. | 2014-11-14 17:55:56 TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2014-11-14 17:55:56 Disconnected from TT FIX Price Feed session. | 2014-11-14 17:55:56 AMP/TTNet | Disconnected. | 2014-11-14 17:55:56 |
[2014-11-14 18:26:37] |
You do not have the correct Service set in Sierra Chart. Follow through the step-by-step instructions here to use Rithmic: Rithmic Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
