Date/Time: Sat, 17 Jan 2026 00:07:00 +0000
Individual volume profile bars
View Count: 2482
| [2013-05-16 14:24:22] |
| User96298 - Posts: 6 |
I currently use the free trial with historical (intraday) data for the ES (S&P 500) future. The other day I wanted to try out chart bars with Volume Profile for each individual chart bar as shown on http://www.sierrachart.com/index.php?l=doc/doc_VolumeByPrice.html (bottom end) and followed the instructions given. Unfortunately the bars were not indicated as shown on this image but fairly messed up (overlapping). Is it possible that individual volume profile bars only work with real time data? Thanks and best regards Jo |
| [2013-05-16 16:34:06] |
Please post an image of the chart with the Volume by Price study set up as you have, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2013-05-18 07:41:42] |
I've uploaded a pdf-file of an image of the chart. Thanks and regards Jo |
| [2013-05-21 02:12:39] |
We do not see any file attached. We do not want to work with a PDF file. Please follow the instructions here: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2013-05-21 16:02:16] |
So here is an image of a chart according to the instructions above: http://www.sierrachart.com/image.php?l=1369151897832.png Cheers. Jo |
| [2013-05-21 18:06:11] |
You just need to increase the spacing between the chart bars. Follow the instructions here: http://www.sierrachart.com/index.php?l=doc/doc_WorkingWithCharts.html#ChangingBarSpacing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2013-05-22 15:03:27] |
Thanks a lot! Jo
