Date/Time: Sun, 05 May 2024 11:57:42 +0000
Can You Please Add Alert Syntax For Point & Figure Bars
View Count: 841
[2014-11-14 14:13:00] |
cmet - Posts: 537 |
In the Available Main Price Graph Identifiers, can you please add something to identify the state of a Point and Figure Bar? For Example: If it is an up bar - PNFUP If it is a down bar - PNFDOWN To indicate the height of the bar - PNFSIZE PNFUP = 1 PNFDOWN = 1 PNFSIZE > 8*TICKSIZE If there's another way to do these (I've tried every combination using H/L/C to no avail),please let me know. If not, please consider adding them (IRT has similar statements in its RTL language). Thanks. |
[2014-11-17 07:19:40] |
This is not something that we would add. You can identify whether a Point and Figure chart bar up or down by comparing the Open value to the Close value. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-11-17 13:06:21] |
cmet - Posts: 537 |
Is there a specific coding reason for that? When comparing the open to the close and using color bar alerts, the colors change during the current bar every time the last price goes above/below the open of the bar. |
