Date/Time: Sat, 04 May 2024 01:44:19 +0000
Specs for historical candles (volume)
View Count: 859
[2014-11-14 02:32:43] |
peaceland - Posts: 95 |
Is it possible to show exact volume for historical candles in a window?
[2014-11-14 04:31:28] |
Refer to this section: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ViewingToolandChartData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-11-14 06:18:06] |
Thanks for the pointer, that doesn't really solve the issue... it only tells you info on the LAST candle, not other candles. I am trying to do some volume research, and cannot do it this way...
[2014-11-14 08:27:57] |
What command did you select to open the Tool Values Window? It definitely shows values for the chart bar being pointed to with one of the drawing tools or the Chart Values tool. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
