Date/Time: Sun, 28 Apr 2024 16:49:45 +0000
Backup Chart
View Count: 1158
[2014-11-14 02:11:24] |
JamesP - Posts: 89 |
Hello, Windows updated and restarted my computer and I hadn't saved my chartbook for a a week or so. I followed the instructions for finding the backup chart but when I move up a folder in windows like you suggested I don't see the back up charts. All I am seeing is 7 folders. ACS Source, AlertSounds, Data, NPP, RIM, Temp, Transact. I am basically looking for the chart book from before todays restart like yesterday for example. Can I access this considering I haven't saved the chartbook lately. Thanks. |
[2014-11-14 04:30:04] |
There will not be any more recent backup if you did not save your Chartbook for a week unless you set Sierra Chart to automatically save the Chartbook. There is an option for this in Global Settings >> General Settings. Also you must be running a version that does not use the Backup folder if you do not see that folder. If you go to to File >> Open Chartbook and set the File Type to Backup Chartbook Files, you will see backup Chartbooks which you can open. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
