Date/Time: Sun, 28 Apr 2024 04:51:26 +0000
backup chartbook files
View Count: 1081
[2014-11-13 23:57:48] |
Don H - Posts: 31 |
when I look in cbak to bring up backup copies there is nothing listed or saved |
[2014-11-14 04:22:10] |
Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html#BackupChartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-11-14 13:47:26] |
Don H - Posts: 31 |
when I go to top of page tabs do not see backup files. what are standard navigation interface steps to follow
[2014-11-14 17:35:07] |
What version of Sierra Chart are you running?
[2014-11-14 18:05:46] |
Don H - Posts: 31 |
version 1205 not sure if I am looking in right place but there are no backups in the dropdown .cbak file in lower right corner |
[2014-11-14 21:16:45] |
The backup folder is located in C:\SierraChart\Backups. You can copy any Chartbooks out of there and put them into C:\SierraChart\Data Version 1205 does support the Backups folder. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
