Date/Time: Mon, 29 Apr 2024 05:17:24 +0000
Adjust multiple Futures contracts
View Count: 952
[2014-11-13 15:33:05] |
QnReally - Posts: 181 |
I like to manually adjust the data for NQ based on the adjustment amounts I have. These adjustment amounts differ from your automatic "Date Rule Rollover, Back Adjusted" method you support. I would like to do this in a batch mode because I have to do this going back a few years each time we roll over to a new contract. Can this be supported in the future? Alternatively, you could support this functionality via ACSIL if it can be done more easily. Thanks. |
[2014-11-26 19:07:12] |
Any chance of considering this before the next rollover? Thanks.
[2014-12-08 22:47:58] |
I suppose it is too late for the upcoming rollover on Thursday. Would you consider this in a future release? Thanks.
[2014-12-09 00:12:17] |
When we initially looked at this, this looked fairly extensive to implement. However, thinking about it now, there is an easy way you can do this which is documented here: http://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ControllingRolloverAmount Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
