Date/Time: Mon, 29 Apr 2024 18:23:11 +0000
SP chart problem
View Count: 916
[2014-11-13 14:31:10] |
User56254 - Posts: 6 |
Hello Yesterday and today, I have S&P datafeed problem with data gap. My broker is AMP and my datafeed is CQG. I call AMP and a technician tell me that all is good with CQG datafeed => He said me that it is a sierra's problem. I send you a screenshot. Thank you in advance for your support. Julien |
F.US.EPZ14 [CB] 10 Min #13 2014-11-13 09_29_22.287.png / V - Attached On 2014-11-13 14:30:16 UTC - Size: 55.68 KB - 323 views |
[2014-11-13 18:49:33] |
Update Sierra Chart by selecting Help >> Download Prerelease. After the update is installed, right-click on the chart before the missing data and select Delete and Download Data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
