Date/Time: Mon, 06 May 2024 06:22:16 +0000
Toolbar text labels disappeared!
View Count: 863
[2014-11-13 09:00:24] |
phaedonk - Posts: 350 |
The text labels in all the toolbar buttons has disappeared, they are now all blank buttons. Nothing I tried helped, including trying another toolbar, restarting Sierra, installing 1212 (previous was 1166). What can I do?
[2014-11-13 09:09:13] |
Generally the solution to this kind of problem is to restart your computer. It is operating system related.
[2014-11-15 19:47:40] |
Yes, that was it. Thank you.
