Date/Time: Sat, 04 May 2024 04:47:01 +0000
Possible bug with sc.SaveChartImageToFile
View Count: 863
[2014-11-13 04:15:39] |
birdaa - Posts: 12 |
Hi, I've written a custom indicator to take a screenshot when I place a trade. It uses sc.SaveChartImageToFile = 1; to take the screenshot. After updating to the latest version, it now errors with the following: Error saving the image file: C\Images\6AZ4-CME.2014-11-13 04_09_46.865.png | 2014-11-13 15:09:46 * I suspect this is due to the colon missing. I've checked my path under the General Settings tab and it is correct. |
[2014-11-14 04:47:55] |
This will be fixed in the next release.
