Date/Time: Fri, 03 May 2024 23:07:54 +0000
AMP CQG backfill problem in ver 1210
View Count: 886
[2014-11-12 22:44:00] |
User46930 - Posts: 28 |
I switched from TTnet to CQG. I noticed I have a different account number with CQG showing from that I had with TT (correct AMP account ID) but everything (backfill, live trading) was ok. Then I updated to 1210. My account number changed to "correct" but I couldn't get historical intraday data downloaded. Always got "Historical Download Skipped" message. Tried Full Symbol Reset, several chart reloads, SC restarts but nothing helped. So I reverted back to 1205 and everything works fine again it seems ...
[2014-11-13 03:51:27] |
We are fixing this now. We are releasing version 1212. Should be out in about 15 minutes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
