Date/Time: Thu, 09 May 2024 00:20:26 +0000
vertical lines
View Count: 826
[2014-11-12 20:25:08] |
User28682 - Posts: 233 |
Hi, is it possible to create two vertical lines in one click? Like 20 bars apart, so I dont have to count back the bars? Set it up in global settings type thing. Thanks Tom |
[2014-11-15 04:46:01] |
The closest would be to use the Tools >> Time Expansion/Projection tools. Refer to the documentation for these for details.
