Date/Time: Sun, 19 May 2024 03:36:11 +0000
Can't get Daily Russell 2000 Future
View Count: 950
[2014-11-12 19:40:06] |
Willson - Posts: 176 |
Using Transact feed. When I use find symbol tools in SC it only returns symbol TFZ4. The chart is a daily chart. I have tried deleting the symbol file. I have tried all combinations of TFZ4 and TFZ14. What is method of obtaining correct symbol and entering it? Regards |
[2014-11-12 23:31:27] |
This is not making sense. If you select File >> Find Symbol and choose the Russell 2000 symbol and press Open Historical Chart, you should get a chart with the symbols properly set.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-12 23:32:04
[2014-11-13 04:55:19] |
I am not creating a new chart. I have an existing Daily chart created using a different datafeed. This chart is referenced in some studies and overlays. I am trying to activate it with the correct symbol using F5 and then using the two symbol "find" dropdown lists. These lists only display TFZ4, which does not work. They work for Intraday data. Regards |
[2014-11-13 05:33:59] |
Use RJZ14
