Date/Time: Tue, 30 Apr 2024 00:38:35 +0000
Studies/Moving Averages
View Count: 1021
[2014-11-12 18:16:00] |
User83963 - Posts: 18 |
During class this morning I noticed the moving averages on my 1 min chart were significantly different than my instructors chart. He thought it may be that my data is not running 24/7 I believe that it is. My tic chart and others seemed to be fineā¦
[2014-11-13 03:43:42] |
The difference will have to do with the data and data differences can be hard to isolate because there are so many variables involved. However, with a 1 minute per bar chart there really should not be a problem. As long as you have all the data it should be just fine. Refer to this section about missing data: https://www.sierrachart.com/index.php?page=doc/doc_ChartDataFiles.html#LocatingMissingData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
