Date/Time: Mon, 29 Apr 2024 10:56:54 +0000
Daily Volumes - Brent (Zig-Zag)
View Count: 1009
[2014-11-12 15:15:16] |
User78442 - Posts: 260 |
Hi, the daily volume shows 56K+ contracts traded but the Total Zig-Zag volumes are significantly lower - Is there a reason?
NSEA-MZ4 15 Min #2 2014-11-12 15_11_08.136.png / V - Attached On 2014-11-12 15:13:46 UTC - Size: 75.37 KB - 335 views |
[2014-11-12 18:23:33] |
Refer to help topic 43.7: https://www.sierrachart.com/index.php?page=doc/helpdetails43.html#h43.7 We're not sure what you are trying to show in that chart image. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-11-12 21:47:01] |
The Zig-Zags show the rotations H-L etc. with Tick and volume count. The volumes on the ZZ highs & lows are not correct based on the overall count for the day. Are they a delta volume count?
[2014-11-12 22:20:29] |
Help topic 43.7 explains this.
[2014-11-13 04:07:45] |
Thanks, I've looked at this and the section on the SC Real time data. 2 Questions; 1) It is obvious the OEC data is lacking both in content (volume stats) and depth ( I only get ~ 1-2 days) for the Brent Oil Contract. If I want to use the SC Realtime data for the Brent Contract (ICE) do I need to pay SC the Exchange fee ($94.50) as well as the broker for their data i.e. 2 x $94.50? 2) Will the SC Realtime feed alleviate/improve the data issues I have with OEC or do you recommend I use a different trading service for this ICE Contract? |
[2014-11-14 04:39:09] |
1. To be clear, you cannot compare Intraday chart bar volume for a day to the Daily Volume number from the data feed. The two will not match. Using the Sierra Chart Exchange Data Feed is not going to cause a match. We already added more historical data for this contract. Restart Sierra Chart and go to the chart and select Edit >>Delete All Data and Download. 2. No. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-11-14 09:03:41] |
Ok, no problem got it.
