Date/Time: Sun, 05 May 2024 21:15:13 +0000
alerts in version with new spreadsheets
View Count: 920
[2014-11-12 15:09:55] |
mayerrs - Posts: 70 |
i just want to let you know, i tried this version with new speadsheets and there must be something wrong because i did not hear the sounds of my alerts. |
[2014-11-12 18:43:19] |
This is too vague for us to help with. You are in a better position to make a determination as to the problem. You need to look at the formulas and look at the result to see what the issue is. If you have a question about a particular formula, let us know what the formula is and what the specific question is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-12 18:44:00
[2014-11-12 19:05:52] |
ok, i have this formula in chart settings: (F5) > Alerts: =OR ((AV>=1000); (BV>=1000)) it was working in sierra with old spreadshets but it is not working in version with new spreadsheets. i have no idea why. for example this vormula: =V>1000 is working in both cases. do i have anything wrong? should i write my formula another way in version with new spreadsheets? |
[2014-11-12 19:25:48] |
In the formula change the ; to a , This should solve it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-12 19:26:03
