Date/Time: Tue, 11 Nov 2025 08:26:06 +0000
parent order issue ver 971
View Count: 2459
[2013-05-16 10:03:38]
User32496 - Posts: 26
when running my code i get this error which has to do with parent and attached orders, yet 2 min. later the signal shows on chart and order is sent correctly (buy/sell 2 mkt + target 1 +2 on limit + stop + trailing_stop_limit + oco all)
what have i done wrong?
thanks
Error log
Trade Order Error: The order quantity for the Parent is 1 and this is less than the total order quantity of 2 for the Attached Orders. Please adjust the order quantities so the parent is greater or equal to the Attached Orders. | 2013-05-16 05:48:49
here is the orders code (which was copied from an example)
// Create an s_SCNewOrder object.
  s_SCNewOrder NewOrder;
  NewOrder.OrderQuantity = OrderQuantity.GetInt();
  NewOrder.OrderType = SCT_MARKET;
  //Define the Attached Orders to be attached to the main Market order
  //Target 1
  NewOrder.Target1Offset = tPriceInput.GetFloat()*sc.TickSize;
  NewOrder.AttachedOrderTarget1Type = SCT_ORDERTYPE_LIMIT;
  //Target 2
  NewOrder.Target2Offset = target2PriceInput.GetFloat()*sc.TickSize;
  NewOrder.AttachedOrderTarget2Type = SCT_ORDERTYPE_LIMIT;
  //Common Stop
  NewOrder.StopAllOffset = stopPriceInput.GetFloat()*sc.TickSize;
  NewOrder.AttachedOrderStopAllType = SCT_ORDERTYPE_TRIGGERED_TRAILING_STOP_LIMIT_3_OFFSETS;
  NewOrder.TriggeredTrailStopTriggerPriceOffset=stopPriceInput.GetFloat()*sc.TickSize;
  NewOrder.TriggeredTrailStopTrailPriceOffset=trailPriceInput.GetFloat()*sc.TickSize;
  //Set up a move to breakeven action for the common stop
  NewOrder.MoveToBreakEven.Type=MOVETO_BE_ACTION_TYPE_OCO_GROUP_TRIGGERED;
  NewOrder.MoveToBreakEven.BreakEvenLevelOffsetInTicks= bePriceInput.GetFloat();
  //When Target 1 is filled, the order will be moved to breakeven +1
  NewOrder.MoveToBreakEven.TriggerOCOGroup= OCO_GROUP_1;
[2013-05-17 09:25:28]
It looks clear that you are setting this to 1 :
[2013-05-18 20:05:29]
i set the order quantity to be an input. the input # is 2 (which i eneter on the settings screen)
[2013-05-21 02:11:19]
And what are you setting the order quantity to? Please provide very clear evidence that there is a problem.
[2013-05-21 12:14:21]
here is the settings of the study set for 2 and the error msg on the log
imageparent issue order.jpg / V - Attached On 2013-05-21 12:13:51 UTC - Size: 309.6 KB - 819 views
[2013-05-21 18:37:03]
We have thoroughly tested this and could not duplicate the issue.
