Date/Time: Sat, 04 May 2024 03:03:31 +0000
When dragging Window tab to left margin it now resets at the furthermost right margin
View Count: 1206
[2014-11-12 00:45:49] |
The Stealthy Trader - Posts: 162 |
So, I have like 155 windows in one of my workbooks. I move them around a lot. Recently when I try to move the last window(right margin) more toward the front(left margin), at a certain point it flies back to the last slot again. Very frustrating as since there's no better option to navigate the window tabs, it takes around 6 separate movements to move a window all the way to the left margin..and now it zips right back to where it was. please help.. J. |
[2014-11-12 03:03:00] |
We are not quite sure what you are referring to. Are you referring to Sheet tabs within a Spreadsheet? If so, then this would be with the Old Spreadsheets and those are no longer under development and we cannot help with this. In the case of the chart tabs in the main window, it is not possible to drag those beyond the visible row of tabs. So either way, we cannot offer any help with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-11-12 04:48:40] |
We saw your email comment and wondered if it was in relation to this thread and we checked the email address on your account and it matches the email message. Based upon the fact that the email message was about Spreadsheets, This confirms that this is about spreadsheets: Recently when I try to move the last window(right margin) more toward the front(left margin), at a certain point it flies back to the last slot again. If so, we cannot fix this. We do not have the source code to that component. This is why we were quite clear in our prior message about this. We know it is disappointing, but this is the basic fact. This is why we are developing New Spreadsheets and we have complete control over them. Please evaluate whether you want to continue to use Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-12 04:49:29
