Date/Time: Fri, 03 May 2024 17:21:38 +0000
How to Clear Incorrect Position on Chart
View Count: 1035
[2014-11-12 00:35:12] |
djcurcio - Posts: 236 |
I placed an order while at my computer and was filled. The chart correctly displayed the position. I had to leave my computer for an extended period so I entered a trailing stop via the Transact DOM. Later I telephoned Transact to close the position. Transact closed the position. Now my chart is still showing the position as open. How can I get rid of this incorrect position display? Delete all data dose not seem to fix this. Thanks. |
[2014-11-12 04:22:48] |
Refer to this help topic: https://www.sierrachart.com/index.php?page=doc/helpdetails80.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
