Date/Time: Sun, 05 May 2024 21:43:23 +0000
Data Problem
View Count: 867
[2014-11-11 20:06:07] |
User57111 - Posts: 25 |
Hi, Can you tell me why I have gaps on Daily Chart but I do not have on intraday chart? |
GCZ14 [CV] Daily #6 2014-11-11 21_05_13.598.png / V - Attached On 2014-11-11 20:05:44 UTC - Size: 40.7 KB - 304 views GCZ14 [CV] 60 Min #8 2014-11-11 21_05_17.606.png / V - Attached On 2014-11-11 20:05:49 UTC - Size: 43.23 KB - 316 views |
[2014-11-12 04:36:54] |
This is explained in this help topic here: Historical Chart Prices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-11-12 09:46:40] |
So Close Price is Official Settlement Price for Historical Daily Chart Bars and I can't change it because I already have disable "Allow Real-Time Updating of Historical Chart" But if I would use real time data like from my broker the close/last price on Daily chart would be last trade price? Is it possible to adjust the Session Times or even better Open Outcry(Regular Trading Hours)in Daily Chart with Infinity Futures. |
[2014-11-12 09:50:21] |
Refer to 12.1, 12.4, 12.8: https://www.sierrachart.com/index.php?page=doc/helpdetails12.html#h12.1 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
