Date/Time: Fri, 03 May 2024 08:21:49 +0000
Bar color changes
View Count: 905
[2014-11-11 18:36:37] |
User359834 - Posts: 2 |
I try to change the color of the 'Bar High-Low Up' bar. I make the change in the Global Settings - Graphic Settings and then in my Chart Settings, I select 'Use Global Graphic Settings'. This is not working for me. Mike B. |
[2014-11-12 03:50:56] |
Refer to: http://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html&CAID=#ColorsDrawWidths Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-11-12 07:59:58] |
bwasi - Posts: 34 |
Uncheck "Use Global Graphic sett"
