Date/Time: Fri, 27 Nov 2026 20:35:13 +0000
[Sticky] [Locked] - Resolving Login Error: Failed to read incoming decrypted data | certificate verify failed
View Count: 21
| [2026-11-27 20:08:13] |
| Sierra_Chart Engineering - Posts: 25512 |
If you receive the following error when logging into Sierra Chart: The connection was closed before a valid response was received. Failed to read incoming decrypted data from the incoming binary I/O stream. error:0A000086:SSL routines::certificate verify failed.
Refer to the instructions here: https://www.sierrachart.com/index.php?page=doc/HTTPCommunicationErrors.php#ResolvingSecurityCertificateVerificationProblem Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
