Date/Time: Wed, 25 Nov 2026 21:23:49 +0000
File might be corrupt
View Count: 11
[2026-11-25 20:44:26]
User974240 - Posts: 7
Bonjour, j'ai dû faire une mauvaise manipulation, mais rien ne s'est affiché sur mon écran, peut être en arrière plan des graphique mais je ne l'ai vu qu'en fermant Sierra Charts.
quelle est la marche à suivre pour remettre mes graphiques en places?
Voici les messages qui se sont affichés. En pièces jointes les "captures d'écrans"
Bien cordialement
E. Brauer
Désolé mais je ne maîtrise pas l'anglais
Private File
[2026-11-25 21:14:35]
From Google Translate:
Hello, I must have done something wrong, as nothing appeared on my screen—though perhaps the charts were open in the background; I only noticed this when closing Sierra Chart.
What steps should I take to restore my charts?
Here are the messages that appeared. I have attached screenshots.
Best regards,
E. Brauer
Apologies, but I do not speak English.
That particular error is referencing your Configuration File. This is the "Sierra4.config" file that is located in your main Sierra Chart installation folder.
You can restore a backup copy of that file by following these instructions:
Resetting Sierra Chart to a Default State / Restoring Backup Global Configuration File: Restoring Backup Global Configuration File
But, it is very unusual for there to be an issue with this file. Typically, when we hear about things like this it is due to your drive being full. Please check to ensure you have drive space available prior to restoring the backup configuration file.
If you do need to free up drive space, then refer to the following for how to clear out space related to Sierra Chart:
Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency
