Date/Time: Mon, 23 Nov 2026 06:54:33 +0000
Blank Chart Settings Window Tabs
View Count: 44
| [2026-11-23 01:14:59] |
| LudaTrades - Posts: 32 |
When I press F5 for chart settings, some settings tabs are just blank. See attached image No text entered in the search bar, I can't scroll and waiting does not make the settings appear, and switching tabs back and forth doesn't work either I got the settings to finally appear by resizing the window repeatedly. Resizing by shrinking the window to top left and then pulling back out seems to be the most reliable method. When I close and reopen chart settings I must do this resizing fix every time Sierra version 2985, openGL on/off, tested with a clean Sierra install on Windows 10 64bit It is a minor issue but I did not see any posts about it, thank you in advance for looking. |
| [2026-11-23 01:49:59] |
| User719512 - Posts: 546 |
Do you have pending windows updates? Have you rebooted your PC? What changed since this stopped working? Does it happen for a new chartbook? If you install previous version, does it still happen? |
| [2026-11-23 03:56:13] |
| Sierra_Chart Engineering - Posts: 25463 |
First thing is to check the relevant Color Settings: Settings Windows Interface: Colors and Font Settings But we see that resizing is resolving the issue. So we are not sure about this issue. We have never had anything like this reported before. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
