Date/Time: Mon, 23 Nov 2026 00:39:29 +0000
Intraday Data Storage Time Unit and Rithmic historical data limit
View Count: 19
[2026-11-22 22:56:19]
User912344 - Posts: 3
Subject: Intraday Data Storage Time Unit and Rithmic historical data limit
I use Sierra Chart with the Rithmic data feed. Rithmic told me I exceeded their weekly historical data limit of 40 GB (about 40.5 GB requested), and my historical data privileges were suspended until the weekly reset. Since then Sierra Chart shows "logon permission denied for historical data".
My setup: a 15-minute chart with Intraday Data Storage Time Unit set to 1 Tick, and weekly Volume by Price profiles. I only need the weekly profiles, not order flow or tick-level analysis.
I have a few questions:
1. If I change the Intraday Data Storage Time Unit from 1 Tick to 1 Second, does Sierra Chart request less data from the Rithmic server, or does it still download the raw ticks and aggregate them locally? In other words, does this setting reduce the bytes requested from Rithmic, or only the size of the files stored on disk?
2. For weekly Volume by Price profiles, how is volume distributed within each bar when the storage unit is 1 Second (or 1 Minute) instead of 1 Tick? Is there a significant difference in the POC and the volume nodes?
3. Is there any scenario in which Sierra Chart repeatedly requests the same historical ticks (for example after connection errors, such as the "unknown request" error I have seen), which could explain such high consumption?
4. What do you recommend (Days to Load, specific contract instead of continuous, etc.) to keep the data requested from Rithmic well under their limit?
Thank you very much for your help.
Best regards,
Omar
[2026-11-22 23:35:50]
Sierra_Chart Engineering - Posts: 25462
We are 100% not getting involved in Rithmic data support or anything related to it.
We are fully declining all support for this now.
Use the Denali Exchange Data Feed:
All users have been extensively warned multiple times about Rithmic data. We do not provide any support for it.
Date Time Of Last Edit: 2026-11-22 23:36:50
